I was driving with a quarter tank then all the sudden it drops to E and my fuel light came on in the top left hand corner. Any ideas?
could be a broke wire (,ground or otherwise ),,failed sender ,failed cluster ,fuse ,,etc etc ,,,
i'll bet ya a dollar that there is a code to pull,,
a scanner can sweep the gauges and also see if the gauge matches data ,,
you must have a service manual right ?,,,if not you need one if doing this yourself
Thanks for the reply. I'll have to get it scanned because i do not have a code reader
Where are the fuses i should check?
idk ,see if the owners manual will help or check all under hood fuses with key on engine off and a test light
I have an 01, sender on mine is going. Mine is on and off depending on it's mood. I have to remember my fills. I had it out last summer and it looked worn, I should have cleaned it up. It jumps all over the place but always lower than the actual fill level on the tank. A lot of times it will read E and I know I have at least a 1/4 tank in it.
Go through all the easy stuff first because to change the sender you need to take the box off.
