hvac temp and vent controls switched
Okay guys and gals i am at a loss. Been doing a bunch of work on a friends 2000 2500 non hd. Part of that included a heater core and cabin air filters. Well now that its back togeather, the temp control knob controls the vent output and the vent control knob controls the temp. I checked all my plug ins for the hvac box harness and i have everything plugged in correctly it seems. I took a diagram off mitchells prodemand and everything matches up. So has anybody ever had this happen to them? Im lost and out of ideas. Figured i just plugged something in wrong but it doesnt look that way. Any help is much appreciated! Thanks
your question is "has anyone else had this happen to them"?
i guess no one has ,,,,
take it apart again ,you did something wrong imo
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
