2002 -- 29' Travel Trailer
Dmax_nani
MODEL: 2002 Sprinter TT 299 RLS  [Excellent Condition]
FEATURES:
- Interior color'Cranberry'
- All ceilings increased to 80"
- Flush floor Slideout
- Separate skylight shower/tub (garden style); washroom and restroom
- Two swivel rocker
- Hide-a-bed sofas
- 45" Dinette
- 20' Awning
- AM/FM/CD player
- Hardwood raised-cathedral cabinet doors and drawer fronts
- Enlarged overhead cabinets (more storage)
- Kitchen sink with deep 60/40 basins with high-arch faucet
- Deluxe fabric & valances
- Carpeting and wallboard w/border
- Laundry chute into outside access storage area
- Brass coat rack near entry door
- Lazy Susan
- Full-function monitor panel
- Range with knife storage
- Oak refrigerator front
- Ducted Heat/Air (15,000btu A/C)
- Microwave
- Outside shower
- 6 gal. hot water heater;
- Cable/Phone hook-ups; TV antenna
- Security blinds
- Smoke detector
- Pass through storage
- Auxiliary battery; Spare Tire and Carrier
- Stabilizer jacks
- Rear ladder
- EZ-Lift hitch and sway bar (INCLUDED)
GVWR:   9680
UVW (Gross Dry Wt):   6780
Carrying Capacity:   2900
Hitch:   880
Dry Axle Wt:   6200
Exterior Length:   32' 11"
Exterior Width:   8'
Exterior Ht (Top of A/C):  10' 10"
Fresh Water Capacity:   45
Waste Water Capacity:   32
Grey Water Capacity:   48
LPG Capacity (lbs):   60
Tire Size:   225/75R15
$19,000.00 / OBO  (Buying a New House)
Thank you for looking.
Nani :thumb:
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 806 Guests (See full list)
