Powder Coated Bumpers
Has anyone powder coated their chrome bumpers and what do you do with the sensors to match the bumper?
I've never done it. But i would imagine powdercoat bumpers and then paint the sensors so they wouldn't get damaged in the heat.
Quote:
is that the stock chrome grill color matched?
Yes it is. We tried to sand blast the chrome to etch it before epoxy priming it. Well as soon we hit it with the blaster it bubbled up the chrome and we had to peel all the chrome off by hand then, adhesion promotor, 2k high build prime, sand, epoxy prime, then base/clear. It was a real pain in the ***!
I found this posted over at performance trucks seems like painting the bumpers can be a real nightmare I wonder if powdercoat would be any easier :dunno:
why not try plastidipping them?
ive used the stuff before, works great and i was thinking about doig the bumpers on mine if i got black but i ended up with grey.
Powder coating them is certainly possible. Like any painting process, prep is important. Color matching will be unlikely, if not impossible. If you want flat or gloss black, you're in luck. Matching metallic...I don't think so. My general feeling about powder coat painting is that it is more durable than most conventional paints (but not all), but it doesn't have the quality of flatness and gloss. It is, after all, melted plastic. Powder coat painting was developed for high production painting. Keep that in mind when you deal with one of these companies that's used to painting hundreds or thousands of the same thing.
If you want to paint a chromed bumper, you might check with a bumper chroming or other chroming shop and have them strip the chrome in nitric acid. No muss, no fuss, no blistered chrome, no grinding marks. But still, you really gotta want a painted bumper bad to go thru all this.
    C. Hart
    C. Hart
  • Who's Online   5 Members, 1 Anonymous, 605 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
