Wireless Charging to Trucks
Thanks for finding that link. Wouldn't mind one bit if that feature made it into my truck!
Well if I'm correct they're building the 15's already, no? I think if the option wasn't there when you ordered it, it won't come with it. [emoji17] then again you never know maybe they'll be super awesome and include the charger mat. :P
But I would think they would at least let the ATS and the 'Slade enjoy it first. Just my thoughts.
The Denali's get Magnetic Ride Control.
OnStar changed to AT&T and dropped Verizon for their service.
A new color is coming too. :P
And I think you could get the 8 inch mylink screen on the work trucks now.
The hotspot is now included standard in the trucks, powered by AT&T 4G LTE.
If I remember more I'll gladly comment here and tell you if I remember/find more.
New exterior colors – Rain Forrest Metallic, Deep Ocean Blue Metallic – are offered across the lineup and a pair of specialty exterior colors will be offered for limited periods during the model year: Sunrise Metallic and Pewter.
Ohh yeah! My bad, I overlooked that it was more than one. Sorry about that.[emoji55]
Don't be sorry! I'm excited there are 4 new colors offered for the 2015 model year.
True. I wanna see what that "Sunrise Metallic" looks like though. I'm guessing a sort of yellow? Lol
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,262 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
