Tie Rod End Sleeve ?
Went to install new set of Moog tie rod ends.
The thread diameter is smaller than my original.
If I somehow close - clamp tighter - bend - outer sleeve diameter to make fit . . .
This will make a smaller diameter outer thread size than the inner sleeve side.
It appears I would need new clamps, since original will not (contour) close the outer thread sleeve diameter enough ?
A new atermarket Sleeve ( at looking in the store ) is same as mine. Slight too large outer thread diameter.
Is this Safe ?
Is this a normal procedure ?
suggestions . . .
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 611 Guests (See full list)
