Ignition Switch Recall
BlueWrapper
I'm currently driving a 2004 Saturn Vue it is not on the ignition recall list but it seems to have one of the exact problems listed in the recall.
The key can easily come right out of the ignition while driving or the engine is running. Is there anything I can do about his since it's the same problem as listed on the recall but not the actual vehicle?
Who would I take it to be fixed?
I would have it looked at by a dealer. Also see if you can get in contact with the GM reps on this board. They surely be able to point you in the right direction.
In the mean time take EVERYTHING off your key ring, including the FOB. Just use the key in the ignition, nothing else. A big problem with this recall is people loading up their keychains with ridiculous weight.
Sounds like the cylinder is worn excessively inside, either the key is smooth as a baby's butt, or the tumblers are shot, or a combo of both. The recalls are about weight on the key putting stress on the ignition switch and force causing it to rotate off, due to a weak ign. switch, so IMO, not the same problem.
Well the key is definitely smooth. So do you think that it's not related to the other problem of the engine turning off while driving?
How do I get a hold of the gm reps here? Nevermind, found them in the 2014 Vibration problem thread and sent a pm.
