Help needed
Sounds like you have a brake caliper that's sticking/dragging. Been there, done that. As previously suggested, after you drive it and it feels tight jack up each wheel and see if they turn easily. You could also simply feel for excessive heat in the wheels. If you have a caliper that is sticking/dragging it will transfer heat into the wheel making that wheel much hotter than the rest. Just be careful not to burn your hand.
Hope this helps. Good luck with it.
Transfer case motor was bad, replaced it. It still seems to have a tighter feeling but the new motor sure helped. Calipers and hubs are next.
Edit: upon investigation in the daylight and disassembly it was the e-brake parts that disintegrated due to the cables being frozen. New rotors and calipers and removal of all e-brake guts and she's back on the road
Left rear axle bearing at wheel let go tonight, any idea on part numbers?where to get?
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 906 Guests (See full list)
