What do you think
booaxle
I have the 5.7 350 in my truck.  I put on a flomaster 40 series, a month ago, at 90 degrees behind my tires.  I was wondering if i need to put on a K&N FIPK kit or should i just go with a K&N Generation II.  I need yalls help.
Thanks
Welcome to the club boo..........
As for the K&N side of things...  Everyone here has there opinions about it and mine is If you feel like spending the 250 bucks then have at it........  I think you could spend the 250 bucks a little better..... :cool:
Good luck
I doubt that you will notice much change with the K&N.
:cool: I would spend the money on something else.
Just my .02 cents.   :thumb:
