Lowering gurus, anything I should know before using bell tech 3 inch l
Slo281
First time lowering any vehicle. Are their any problems I need to prepare for or anything to watch out for. It's a 2 inch lower shackle and block remover to make a 3" drop. Going on a reg cab 5.3
First time lowering any vehicle. Are their any problems I need to prepare for or anything to watch out for. It's a 2 inch lower shackle and block remover to make a 3" drop. Going on a reg cab 5.KJ
Just did this to mine. Pretty straight forward. Nothing to watch out for.
How has the quality of ride been? Also, did u do the exact drop?
Nothing changed at all. I put on the 2" shackle and removed the 1 1/4" block.
Cool, did u have to cut or do any modifications?
    Dom Colussi
    Dom Colussi
  • Who's Online   2 Members, 0 Anonymous, 483 Guests (See full list)
