Truck sputters on cold start
Ok I have a strange problem that has me stumped. I have a 2011 Chevy Colorado with 78,000 miles on it. This only happens when the truck sits for 6 to 8 hours. I start it up and it fires up right away no problem. It runs at 1000 rpms for 30 or 45 seconds. kind of the choke mode. it then drops to around 800rpms 3 seconds later it sputters and almost dies. it does this 3 times in a 30 second period then goes back to normal rpms and runs great! I'm getting 26 mpg it is the 2.9L 4 cylinder fuel injected engine. and its throwing no trouble codes? Its so weird you could probably use a stopwatch and get the same time every time? I have changed spark plugs, cleaned the MAF sensor, cleaned the throttle body, tried a better gasoline and ran seafoam through the system. The battery is strong the air filter is clean and the oil is changed regularly and I see no visible air leaks? nor do I see any fluid leaks and there is no smell of gasoline. I have looked all over the net for answers and have gotten some good ideas but I have yet to find a solution? Anyone have any ideas? anyone have this same problem? Any help would be greatly appreciated! Thank You!
  • 4 years later...
I have a 4 cyl 05 Colorado.  Summer starting is fine.  This problem is most like mine. I solved the starting problem by disconnecting the coolant sensor.  Now this is not a good solution because the engine things it is -40deg all the time. So, for some reason a cold water temp messes with a cold start, but why?  Bad computer?  Any Ideas?
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
