Help Needed -- Remove Upper Box Molding?
Hi, all --
The Sierra gets its first few "big" mods (i.e. big to me, minor to most of you here) on Tuesday, when it goes in for a Line-X coating and gets its BAK Roll-X installed by yours truly.
I'm also going to be installing a BAK Box down the road which, if I understand correctly, will likely limit access to some of the forward mounting points for the OEM removable tie-down anchors. I'd still like to get some usable forward tie-down points, so I was thinking about putting in a pair of Bullring anchors into the forward stake pockets.
Here's the problem: those forward stake pockets are covered by the upper box molding. I suspect it's easy enough to Dremel plastic away from the area and expose the pocket, but I'd prefer to do this with the molding off the truck so I don't ruin the paint.
So, that's my question -- is there a way to safely (and hopefully fairly quickly) remove the upper molding?
Appreciate any advice anyone can lend...
-Evan
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
