Breakthrough-Drug approved for AIDS
SnakeEyeSS
just saw on a CBS "Health Watch" commerical that doctors have developed an apporved drug that stops the spread of AIDS inside the body. I guess that a step closer to the cure.....
Well one of the problems that was associated with all the other drugs out there to help fight the spread of AIDS in your body was that the virus built up an immunity to them and after a while, the drugs became useless.  Hopefully this new drug won't do the same thing! :thumb:
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 1 Anonymous, 549 Guests (See full list)
