Adding backup camera need help
nibroc92
I'm adding a auto spa tech camera to my truck and need help with the wiring. I have the wire ran to the new module. The instructions say to plug the wire into the gray connector space 5 and 6 my connector already has wires in spaces 5 and 6 what should i do? The wire is labeled video positive and video ground
are you sure you are looking at the right end because that is where the video wires go
  • 2 years later...
Yes the gray connector to the hmi labeled j2
Did you ever figure this out?
It's easier to add the factory camera. The plug is under the truck if you have a 2015+. Plug it in and then get the HMI module, that your gonna get for your gauge cluster upgrade, to accept it. I believe there is a topic on it on here.
Does anyone here know where I can find this female terminal?
Delphi Connector
Terminal
  1. the first image is the delphi 12 pin connector
  2. the second image is the female terminal that I need.
All this belongs to the HMI J2 connector.
I need this terminal to complete my OEM backup camera wiring on my 2014 Silverado.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 475 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
