Datlight running lights
gss036
I have a 99 Silverado, new body style, I have a daytime running light out on the left side, I thought it would be simple to change but I cannot get to the fixture to change it. Help Please?
1-remove the 2 pins holding headlight  assembly in--pull out to expose light assembly underneath headlight
2-reach down behind running light unit -twist and remove housing
3-remove burnt bulb---remember not to touch new bulb with bare hands--use paper towel or rag --reinsert new bulb and reverse assembly directions above--should be a snap  job---real easy fix :devil:  :flag:  :flag:
What troyrobo said.  I remember the first time I had to replace one of mine, I looked in there and thought OMG how the heck am I ever gonna get to that?  ???  ???
Then I started fooling around, and took a closer look.  It's also spelled out in the owner's manual, strangely enough.
Actually, when you see how slick it works, you feel foolish!!!  And it sure beats having to become a body contortionist!!!
BTW, welcome to the site and forum!
:hail: Many thanks, I just knew there had to be a simple way.
I replaced a headlight assembly on a 1996 Ford Tarus for an elderly lady this past weekend, it was kinda like a jigsaw puzzle.
Is there one of the Forums here that deal with engines, I would like to read the posts to see if others have had they same situation as I and a friend had with our new trucks.
whats the situation?  Knocking?
Try the Light Duty forum or engine forum
:popcorn:  I just wanted to read posts on the subject. I went thru it with my new truck, GM rebuilt the engine at 11K and didn't fix it, then at 15K dropped in a brand new out of the box factory engine. So far no knock(piston slap). I did get a letter on the engine extending the warranty out to 60K / 5yr.
  • 1 month later...
Got a question. what is it with these :smash: running lights? I swear I see at least 1 out of 4 GM/chevy trucks with burned out running lights
On my '89 GMC, I run my lights all the time and it was just this year that I had to replace a headlamp.
Are the running lights any better on the '03's?
bought my truck used---only replaced 1 so far-- 1 yr to date------ :smash:  :jester:  :bs: ------now i've done it---probably have to replace another 1 now that i opened my mouth about it
There is an easy way to change these bulbs.
Look at the light back where it meets the fender
and there is A release tab to take the light right out
of the truck.
Hope This Helps
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 410 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
