My horn blows,
You probably have the insulation rubbed off of a wire some where and when you honk the horn it grounds out and blows the fuse.  But what do I know it could be something else.   :flag:
Remove the plug from the horn, then push the horn button. Does the fuse still blow?
If it does, then you have a wire shorting out, if it does not , then you have a bad horn.
check these out,
Tom
