Transmission/Shifting
I've been experiencing a delay in the transmission; whenever it's time for my truck to shift gears its a one til two second delay before it shifts or if i'm on the highway and have to come of the accelerator and accelerate again there is a delay like a hard shift. Has anyone else experience this?
I'm sure acuzillion people have ,, you need to to see a trans shop , just saw the yr of truck you have ,just take it in for a warranty service visit
Report back please what they found
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
