6.2 Cold Air Intake
Watch your k&n's and any other filters for passing fine dust. Most oiled air filters do and my impact warranty. Seeing as most people here are concerned about oil in the intake, I'd bring this up too. I've seen some nasty intake tubes with even properly oiled air filters. The worst being dusted turbos in duramaxes
From personal experience, I completely agree. On a previous vehicle, I had a K&N filter that was good about passing fine dust. Wider mesh gives better air flow. It caused the MAF to flip out twice, which would go away if I cleaned it off. After the second time, I noticed the intake was rather dirty as well. Wiped everything down and went back to a boring quality paper filter, and the MAF problem next came up again. Haven't used one since, as possible power increase isn't worth the more likely dust-related issues. Each to their own though.
From personal experience, I like dry synthetic filters more. When AEM first came out with theirs, it seemed great, no dust. Put a round one on my old '01 5.3 that was grey. But I bought an AEM square direct fit for my Duramax a year ago, and they had dyed it red (even had red blotches around the sides to look like a K&N) and that one passed a small amount of dirt. So I dunno if you can figure out the filter micron ratings but definitely do so.
I'm still looking and can't decide oiled filter or dry I have a Dry AFM in there now, but I want more HP. Have exhaust, chip and tune. Now just need CIA and gears...
I have a dry synthetic filter full Airaid Kit. It sounds awesome at full throttle and you can definitely feel the power increase and better throttle response. :)
  • 1 year later...
    CockneyUSA
    CockneyUSA
  • Who's Online   4 Members, 1 Anonymous, 756 Guests (See full list)
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
