Torsion bar adjustment and alignment
I cranked my torsion bars all the way up to level my 01 Silverado. It helped a lot.  My question is does this affect alignment?  My front tires are all chewed up on the outside edges after only 4000 miles on the new set.  I put the front ones on the back and vice versa and I had such a shake in the steering it was violent.  I put the tires bak but crossed the front tires.  I now have a slight wobbl ein the wheel but a hard pull to the right.  It used to pull to the left.  What gives?
Yup, it throws the alignment waaay off.
The tow-in, I believe is what it's called. This would definately make your tires wear in the pattern you are indicating.
You should get it aligned ASAP.
Yes you will need an allignment. I caution you about cranking the bars all the way to the top. It will bind the keys aginst the top of the bracket. They need some room to flex as part of suspension flex.
I was told by another person that the max you can go with out needing an alignment is 3 to 5 full turns, but he said the most important part is to bounce the front of the truck to see how the tires sit  :thumb:
So why is it that adjusting the highth of the truck changes the Front alignment?  :nono:
Changing the static ride height changes the static alignment.  On independent from suspensions, that utilize SHORT LONG ARM suspension (SLA), the tire moves through a very large arc as it goes up and down, it does not stay perpendicular to the road surface. This changes the camber of the wheel through the wheels suspension travel. So by raising the static ride height, you are changing the camber, and can affect how the tires wear and the car pulls. Ideally it shouldn't, but if the camber changes it responds differently to loading. If the tires are pushed out at the bottom after a lift (which they will be because the upper arm is shorter so it pulls in the top of the tire as it droops) the tires will try to push in on the truck. If one side is loaded a little more than the other, that tire will have more grab and push the truck opposite that side.
Changing the static ride height can affect the toe in as well, since the steering linkage doesn't move in perfect harmony with the control arms. Normally this slight variance can contribute to bump steer as the toe changes through the suspension travel. However, for static ride height, it will change the direction the truck wants to steer.
Chris
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
