Transmission Gear Selection indicator slow to respond
04 Silverado 1500 Z71 - When I shift from PRND21 - The display on my cluster is slow to respond. I solder and re-soldered all the connections on the back of the cluster and replaced the transmission selector switch on the side of the transmission. Still no joy. Any other suggestions? BTW - The transmission goes into gear immediately, so mechanically I do not think there is anything wrong.
TIA
Vince
Must be the cluster , idk if the pressure switch on the valve body provides info to the cluster or not ,
I thought the NSBU switch on the shifter shaft tells the PCM only what the operator pics as a gear ...
Replacing the cluster is out of the question for this minor irritant ,
Maybe throw a pressure switch at it next tranny service if it makes you this crazy
    BigJake
    BigJake
  • Who's Online   4 Members, 0 Anonymous, 652 Guests (See full list)
