silverado part question
I had one of the caddalic engine covers on my 2015 5.3 silverado. I traded it in on a 2015 silverado with a 5.3. The two front studs that the engine cover snapped on too are not on the 2015. There are just 2 bolts. Does anyone have access to a part number for these bolt/studs. Thanks.
Best idea I can come up with:
find a caddy that has the parts you need on ebay or a car lot. Get the vin, email gmpartsdirect customer support with the vin and the parts you're lookin for, and they'll give you a PN.
They're really good about helping you out on this kinda thing.
I'd like to see what this looks like. I know up until this point we've had engine covers. Seems like they dropped that idea for us in the k2s.
I had these on my 2014. They are not on 2015. I am looking for 2 or part numbers?
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 700 Guests (See full list)
