22" fitment question.
I have 305/45r22 hankook dynapro atm with +31 offset dub's and rancho quicklifts that gave me about 2.25" of lift and I rub the sway bar. I've ordered some 1/4" spacers to hopefully clear them. I was also rubbing on the inside of the fender on the liner, I had to drill holes in it and zip tie it back further, It just barely clears now. I would imagine you're going to run into some serious rubbing issues with that.
The tires you're looking at are just under 35" x 13". Youre going to need a more offset rim or some larger wheel spacers, but even then I would imagine you will rub the fender liner even worse with the spacers. You will probably be looking for at least a 3.5" lift to fit those, but I would say 4-5" is probably more ideal.
Do you have any pictures. I was looking at that size but thought they would look too small. I have a 2.5" rough country in the front and a readylift 2.25" in the rear. I think I will run a 1/4" spacer anyway to get closer to my factory +24 offset.
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 686 Guests (See full list)
