leveling kit installation help
I tried to install the 2 inch from shock spacers and couldn't push the front hub/wheel down far enough to put slack in for the spacer to fit. does this mean I have to take the front torsion bar off? is there any videos/youtube someone might know about for how to install this? search has not shown anything for me.
If it an 07-13 you have to loosen the sway bar to give you the extra clearance and sometimes you have to loosen the upper control arm also.
Loosen the sway bar linkage, or disconnect it. If that doesnt work try disconnecting the upper ball joint.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,129 Guests (See full list)
