MyLink Weather App?
I've read a few articles on the "AppShop" by GM.. not sure if they actually went live with it, or just put it on the back burner because of the plans with Andriod and iOS systems for next year so here's my question..
Without the factory NAV system, can I add the weather app to my '15? I do have the wifi in my truck, and will more than likely keep that as long as I don't need a full subscription to OnStar for it.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 453 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
