Turbo/turbine sound when I accelerate 2015 Suburban
Has anyone noticed a "turbo" sound when they accelerate? It can be heard through all stages of "start and go" until the sound is masked by outside noise and can't be heard anymore. Dealer can't find the issue, and the vehicle drives fine, but the sound can't be remedied.
Most likely the exhaust flapper valve. Helps cancel drone in 4 cyl mode. 1/4X20 bolt and a nut and you can keep the valve open and cancel out the turbo/whistle sound.
  • 1 month later...
I'D have the rear diff looked at. Ours did this as well. Noticeable whining sound while acceleration and deceleration . MANY customers are finding abnormal wear in the front and rear Diff's. Just add it to the list of design flaws with the new 2015's.
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
