B0015 driver pretensioner short to battery
please a little help think this is in your wheel house ChevyTech77 ! I was reading exploding seatbelt post > brother just bought truck 08 Silverado 2500HD from state auction has airbag light on code for short to battery on trigger ckt. traced wire from tensioner to module not bear any where connector had some corrosion cleaned with contact cleaner and brush no change can I ohms test pretensioner to verify good and can I multi-meter input leads to pretension for a specific value ? air bag module underseat the case severely corroded concern hole thru and moisture has entered so short inside module ! is this a recall item do you know off hand? can I verify failure of pretentioner before ordering replacement? thank You very much for any and all your help this communitity has been so helpful with stumpers of this old school fool! Sincerely Kevin read post with Srs codes but says link no longer works when try to go to specific B Code So reassembled and missed kick panel connecter no communication with module reconnected code for front sensor and driver air bag shorted to battery things that make you go hum! disconnected passenger pretentioner instant short to battery code for passenger side pretentioner so leads me to bad pretentioner on driverside still would like way to test to verify!!
so had kick panel connecter disconnected and no communication with module reconnected and had code for driver air bag and front sensor code after reconnecting? so disconnected passenger pretensioner instant code for passenger pretentioner shorted to battery so deductive reasoning tells me looks like have bad drivers side pretentioner thanks everyone if you can shoot me a test to verify that's great
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
