Concrete Curing in So. CA
gnet158
I'm having a small area of my back yard concreted (25 feet long x 8 feet wide) on Saturday and have a few questions.
1.How long does concrete take to cure?
2.It's a little cold here in CA daytime highs 63 with nighttime lows of 52.  Will this effect the curing time?
3.It's supposed to rain on Sunday.  Is there anything I need to do?
Thanks for your help!
:cool:
Despite my screen name, I do not deal in concrete.  But from all the concrete I've layed (keep your minds out of the gutter).
- Hard enough to at least walk on is withing 12 - 24 hours.
- Hard enough to drive a vehicle on, I'd wait at least 48 hours, maybe more.  I think when I did our supplemental driveway, I waited a week just for safeties sake.  But you don't need to.
- Temps, those will be fine.  You don't want to do it when it's too hot either, otherwise it cures too fast and after which the top layer will flake off in spots possibly.  Old mixed CMNT can also do this same thing (say if it were mixed 5 hours or so before being put down, formed, and cured).
What I've seen them do here in Chicago with the new Wacker Dr. construction (which is concrete), after they get done shaping/forming it and ready to let it cure, they put a white plastic tarp over it to protect against the elements.  I think it was a breathable plastic though that let's air and some moisture from rain through on purpose.
Thanks for the reply.  So I think your saying that as long as they (I'm defiantly not skilled enough to pour concrete so I've paid for someone to do it for me) cover it with the mentioned plastic tarp then I don't need to worry about the rain?  Thanks! :cool:
Nope.  Heck, they poured it in winter, covered it with the tarp, and it snowed on it.  So I wouldn't worry much.
If they do it this way, they may not.
There's a whole multitude of factors involved in concrete curing and strength, etc (my Dad was a contractor and I got a lot of time on a bull float), so I'm not gonna go into details.
The best way for concrete to cure is slowly - that way the water fully hydrates the concrete.  You slow down this process by covering w/ plastic, tarps, even straw as was mentioned, or even watering lightly at first, and also there are curing compounds that are sprayed on after the concrete has been completely finished (You don't cover and wet until it's completely finished, either). You usually see this as a white powdery looking substance sprayed on new concrete roadway surfaces.
24 hr is certainly fine for walking traffic, but I'd really say stay off it w/ cars, etc for 1 week.  Even though concrete may be firm enough to walk on in less than 12 hrs, depending on the local conditions, etc, there are a whole world of chemical reactions still going on, and it's in this time that the concrete is fully hardening, this is really the curing process, as opposed to the setting process, which starts as soon as the wet concrete mix is poured into the forms.  I'm sure the contractor will know how to do all this.
I can definitely say that if you're not sure what to do, let the pros do it - this is one area that is a killer to re-do as you only get one chance when the concrete is first placed wet into the forms - after that come he** or high water, it's gonna set up. :flag:
That's my 2 cents.   :cool:
BTW, the reason they can cover concrete in Winter like CMNT mentioned, is they had probably added calcium or another agent to keep the liquid water from freezing while it hydrated the mix.
Concrete reaches it's maximum compressive strength at about 28 days.  It keeps getting stronger as time goes on, but the curve drops off substantially.  You can usually place concrete down to about 30 degrees without havig to cover it.  The heat generated by the cemical reaction of Portland Cement and Water generates enough heat to keep it warm enough.  Good luck, and make sure you put a date or your kids hand prints in it somewhere inconspicuous.
My dad was a concrete contractor in southern Ohio. I worked on his crew many summers. What BlueRado says is word. One of the hardest jobs I have ever had to do was demoing a 60 year old 6" thick concrete porch with a 16 lb sledge hammer. It was hard as diamonds.
I helped an old neighbor break-up, and haul off a poured concrete in-ground pool, as well as the surrounding walkways.
To add insult to injury, after we finally got it all out....We then had to fill it up with dirt....The same way we got the concrete out. One wheelbarrow at a time. No backyard access at all.
Yup, one of the most backbreaking weeks of my life.
"If it doesen't kill you it will make you stronger"
It should have added "....and will make you walk funny for a month". :cheers:
It should have added "....and will make you walk funny for a month". :crackup:
:eek:  :cool:
Couldn't agree more!!!!
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,271 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
