Camper tie downs
kokobird
Hi .. I looking at purchasing a 2011 Silverado 2500HD 6 lit . I will be using the truck to carry a 8'6'' Bigfoot Camper .
I will need tie downs for the front the choice is belly bars or individual each side ?
For the back since the truck has a hitch I thought of using a bracket each side mounted to the tow hitch . Not viewing the truck yet does anyone know if the OEM hitch frame mounted cross bar is square or round ? ( i was thinking of using the ones i have off a 2003 ford F350) which attach to the hich bar with " U Bolts ")
Any info or suggestions are appreciated .
Thank You
  • 3 weeks later...
Torqlift were the tiedown of choice back about ten years ago...I had a Happi-Jac setup, and it was by far to light for large slide ins.
Sent from my SM-T350 using Tapatalk
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,242 Guests (See full list)
