Just wondering if any one knows on the new 5.3's is the engine fan have left or right hand thread on it..   was thinking of pulling it off, and seeing if my electirc fan can cool ok..
any one done this?
Matt
I've found that a 1 7/16 box wrench and 3lb mallet work good to get the fan off. Hitting the other end of the wrench with the mallet will loosen the fan. Just try not to miss :eek:
Tom
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
