Light bar opinion?
I have run a bunch of different Chinese light bars from cubes to larger and up to 50". The light output is generally less than a Rigid but once you go past 32" it's still a lot of light.
The common issue I have seen with all of them is they have crappy weather seals. Half of the ones I have had end up fogging. We have taken a few apart when new to try and seal up better. The hardware is cheap and can strip easy if not careful.
You do get what you pay for but honestly I do not need a $1500 light bar so $150-300 ones which seem to last 3-5 years which is how long I keep the truck anyways does the trick.
Yeah I hear you. I've been doing some research on these lights and most of them have seal issues, but if I do get one I would already know to take it apart and seal it up better. Now with the LEDs going out then I guess I'm shit out of luck. I have been looking at the rough country light bars and there prices are not that bad. I know there a suspension company but they do have a 3 yr Warrenty. I think I might have to go that route.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 1 Anonymous, 620 Guests (See full list)
