Another Floor Mat Question - Need advice
Hey guys - I think I've read all of the floor mat topics that I could find and I am fairly certain I am going with the Husky's. My only question is regarding the rear mat. I have the rear seat storage bin on it's way so I am leaning towards the smaller rear Husky liner vice the full liner. That said, has anyone tried to see if the bin will fit correctly with the full liner underneath it? Thanks!
Thanks! I ordered the factory GM bin - but I assume it should fit just as well as your Husky one - no? I think I am going to order the Xact ones and the full rear liner. I'll let you know how they work together! Appreciate the assist.
yea it should fit just as well...i got the husky cause its beefy and the price was right. def go with the full liner u wont regret it. good luck
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 641 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
