'03 silverado 1500 front end bang
I have an '03 silverado 1500 Z71 4wd with about 112kmi and my problem is....I first noticed a noise coming from the front end about a month ago and it would make a rattling sound for a couple secs from the front end, but it would happen very sporadically. Well, last week i was driving and it made the noise again for a couple secs, then i went to go stop and eat somewhere......get back in the truck and it seemed like every foot I moved, it would made this pretty loud banging sound. I tried limping it to a side street, but I just didnt want to take a chance on damaging something worse and had it towed back to my house. I jacked the left front up to see if I could see anything broken....drained the front diff oil...but didnt see anything broke nor chucks of metail....just shavings. I am up in the air as to what it might be, so hopefully I gave you guys enough info to lead me in the right direction, thanks.
The first thing I would do is Jack up the front end and spin the tires. Try to identify which side its coming from. You did not mention the speed of the banging sound, at least if it kept pace with the motor or wheels. It probably would not be the front differential because it was not engaged. But the half shafts would still turn. I would lean towards cvj or wheel bearing.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
