Don't mess with NASCAR fans
Elwood
NASCAR fan faces prison time for flooding Fox with angry e-mails
By MARK PRATT, Associated Press Writer
April 16, 2003
BOSTON (AP) -- A NASCAR fan faces up to a year in prison for flooding Fox Entertainment with more than a half-million e-mails because he was angry the network aired a Boston Red Sox game instead of an auto race.
Michael Melo of Billerica has agreed to plead guilty to a federal misdemeanor charge of damage to a protected computer system, his attorney said Wednesday.
The action forced the network to shut down part of its Web site.
Melo designed a program that repeatedly sent the same six e-mails to Fox Entertainment Group Inc. in Los Angeles over a few days in late April and early May 2001. The messages were sent through the company's Boston-area affiliate, according to the federal complaint.
``He was just very upset that the Red Sox would pre-empt NASCAR, so he decided to send these messages to express his views,'' said Melo's lawyer, Andrew Good.
Fox received more than 530,000 e-mails from Melo. Fearing a hacker was attacking its computer system, the company shut down a portion of its Web site, costing Fox $36,000, according to federal prosecutors.
Also, by taking a portion of its Web site down, Fox Entertainment was unable to communicate via computer with WFXT-TV 25 in suburban Boston for several hours, and left the local affiliate unable to receive viewer e-mail, prosecutors said.
The federal complaint did not specify the exact content of the e-mails.
Fox Entertainment spokesman Scott Grogin declined comment.
The charge carries a maximum of one year in prison. Melo, who works in the computer industry and has no prior criminal record, will ask for probation, Good said.
``There was no intention to cause any of this damage and the government isn't claiming he did,'' Good said. ``It happened, but it was produced by machines running wild. He's sorry it happened, obviously.''
A message left on an answering machine for a Michael Melo in Billerica was not immediately returned on Wednesday evening.
No date has been set for his plea hearing and sentencing.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
