ground issue 06 2500hd 6.0L
how many ground wires are there and where are they all at?will run rough random misfires then go over a bump run fine bump back to misfireing....ground right?
Mechanic’s answer
http://www.justanswer.com/chevy/0sa52-need-locate-grounds-truck.html
G100
In the Forward Lamp Harness on the Lower Left of the Radiator Core Support
Power and Grounding Component Views in Wiring Systems
G101
In the Chassis Harness, left side of the engine near the generator
G102 - Except 4.3L
In the Engine Harness, on the left side of the engine block, #3 cylinder area, below the exhaust manifold
G102 - 4.3L
In the Engine Harness, Right Front of the Engine near the Crank Sensor.
G103 - Gas
In the Engine Harness, on the Left Rear of the Engine Block
G103 - Diesel
In the Engine Harness, on the Right Front of the Engine Block
G104 - 4.8, 5.3, 6.0L
G104 - 4.3 and 8.1L
In the Engine Harness, on the rear of the left Cylinder Head
G105
In the Main Battery Harness, Main Battery Ground on the Right Front of the Engine
G106
In the Main Battery Harness on the Right Side of the Engine
G108 - Diesel
In the Engine Harness on the left front of the Engine Block
G109 - Diesel
In the Engine Harness on the Right front of the Engine Block
G110
In the Chassis Harness on the frame to the rear of the left front tire.
G200
In the HVAC Harness, on the Right Side of the I/P Near the A-Pillar Below the I/P Top Cover
G203
In the I/P Harness, On the Left Side of the I/P Near the A-Pillar Below the I/P Top Cover
G302
G304
In the Body Harness, Under the Passenger Seat
G305
In the Body Harness, Behind the Drivers Side B-Pillar Trim Near the Bottom
G306
In the Body Harness, Behind the Passengers Side B-Pillar Trim Near the Bottom
G390 (Crew Cab w/Rear Window Defog)
Defogger Grid Harness, Near C-Pillar
G401
In the Chassis Harness, On the Spare Tire Hoist Assembly
G402 (Export Only)
In the Chassis Harness, Near the Rear Bumper Assembly
G403
In the Chassis Harness, Near the Left Rear Body Mount
G410
In the Body Harness, Right Rear Interior of Vehicle Behind the Right Side Cargo Area Trim Panel
  • 2 months later...
Does anyone have pictures of locations of ground wires for 2004 Sierra 1500 SLE 4.8L? I think I am having grounding wire issues with my truck and the above links are not working. I want to locate them all and sand down and clean up the connections/contacts, if I know where they are.
Thanks for your input in advance.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 501 Guests (See full list)
