looking for muffler
i just got my grandpas 98 chevy 2500hd 5.7L exd cab 8 lug long bed. im looking for some rumble. im not looking for streaight headers or anything like that. i want something that sounds about a flowmaster 40 series. the truck is all stock and has what seems to be 3'' pipes dualed all the way back till the muffler. it is dual in and single out. just looking for some opinions. ive been doing some research but figured id talk to yall since yall actually have the same truck
