Vinyl Wrapped Interior Pieces
EZ Money
I have an SLT with black leather. The factory wood grain is a std. burlwood style. It doesn't really match the black interior.
Has anyone wrapped the wood grain with a different wood grain? I was thinking about using the 3M Di-Noc Black Walnut. Anybody have any experience with this?
I was planning to us the 3M Primer 94 and pull the pieces so I could completely wrap them, as opposed to just tucking it into the crease.
3m Di-noc is not meant to be a super conformable media. It would probably work for some of the interior pieces but anything with some complex contours may not hold over time even with primer 94. Just my thoughts. I have used Di-noc on flat wall surfaces with no issues but it is rigid in contrast to true wrapping films. 3m does say that it will stick to virtually any substrate though. I would probably skip the primer 94 because if you chose to remove the di-noc later it leaves a bit of an adhesive mess. I like to heat and pull the vinyl about a quarter inch around the back to keep from any puckering around the edges.
Sent from my SAMSUNG-SM-N910A using Tapatalk
3M 1080 is your best choice, DINOC is typically used for exterior I do believe as it is a heavier vinyl.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 414 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
