New black tow mirror covers?
Does anyone know if there are chrome covers for the new Black tow mirrors. The one that have the amber light on the front and the blinker and puddle lights?
  • 3 months later...
I have brand new take off chrome covers for sale for those mirrors on ebay right now. I just replaced them with the black covers
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
