Leveling kit tire size
I'm new to the forum and I'm sure this has been said before I've looked up and down been on custom wheel offset and everything but can't find an exact answer I have a 15 ltz71 and I put a 2.5 inch leveling kit on I want to get 17x9 wheels with a negative 12 offset what size tires could I fit with little to no trimming I'd like 33x12.50 also looked at 285/70/17 and 305/65/17 any help would be appreciated in advance thank you
33"s will fit under a 2" level so you will be fine on those
I'm not sure that will clear with a negative offset. Check this site to get a better visual of where it will put the wheel at compared to what you are runningcurrently. I went with a +10mm offset and I run a 285-70R17 with no issue at all and it will clear a 33" tire.
http://www.willtheyfit.com/index.php?width=265&aspect=65&diameter=18&wheelwidth=8.5&offset=10&width2=285&aspect2=75&diameter2=17&wheelwidth2=8.0&offset2=10#content
    Camyon
    Camyon
  • Who's Online   4 Members, 1 Anonymous, 1,256 Guests (See full list)
