2000 Silverado 4wd problems
B WUKE
I have a 2000 Silverado Z71 with Auto-trac. With all four wheels off the ground the 4wd engages and the front wheel spins but I can stop it with my foot. The front drive shaft stops also. Is this going to require a complete rebuild or is it something more simple?
I am not sure that test is going to give you a result you can draw conclusions from. Was the truck idling in drive? Were the rear wheels also turning? When you stopped the rear wheels instead of the front wheels, what happened? Does the auto-trac have a "lock" setting, or is it just a simple all wheel drive with a viscous coupler between front and rear axles?
Was the t-case in 4hi or 4lo? If it was in 4auto this may be ok. Read this info from another thread and your question may be answered
An information bulletin from GM
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,137 Guests (See full list)
