Anbody work for Chevy?
I saw someone post on this board that all they needed was a VIN and they could pull up all the TSB's on a vehicle?  Can anyone do this for me?  My warranty will run out soon and I would like to make sure everything is fixed.  Also, do you know if Chevrolet will fix the slip yoke problem on a truck that is out of warranty?  My brother's truck has 47k on it and it does the clunk pretty bad.  Mine did the same thing...got it fixed.  Thanks.
Check here for All Data TSB's
Automotive Recalls and Technical Service Bulletins,
Year Selection  (1960-2003)
Provided by ALLDATA
Automotive Recalls and Technical Service Bulletins are listed by Year, Make, Model and Engine Option . Select a Year, then a Manufacturer, to see a list of Recalls and Technical Service Bulletins (TSB) for your car or truck.
Amazing...that is a goldmine.  Does anybody have an account where I can get the complete details of the TSB's?  It is so tempting to purchase...I see a few of them that pertain to my truck.  Thanks.
  • 4 weeks later...
What about TSB on the following:
Bulletins for 2001 Chevy Truck K Tahoe 4WD V8-325 5.3L VIN T SFI
01-07-30-042A DEC 02 A/T - 2-3 Upshift or 3-2 Downshift Clunk Explanation
02-05-26-001 SEP 02 Brakes - Rear Park Brake Service Kit Available
I'm wondering because I have that "clunk" between second and third gear and my parking brake goes all the way to the floor. I took it to the dealer concerning the parking brake, but the dealer said he adjusted it and informed me that alot of the parking brakes on the Tahoe models do this. :cool:
I would appreciate the information on these TSB so I could walk into the dealership with some ammo. Thanks ~
Noise #01-07-30-042A - (11/26/2002)
Information on 2-3 Upshift or 3-2 Downshift Clunk Noise
2003 and Prior Light Duty Trucks
with 4L60E or 4L65E Automatic Transmission (RPOs M30, M32)
This bulletin is being revised to add the 2003 model year as well as information about 3-2 downshift. Please discard Corporate Bulletin Number 01-07-30-042 (Section 07 - Transmission/Transaxle).
Some vehicles may exhibit a clunk noise that can be heard on a 2-3 upshift or a 3-2 downshift.
During a 2-3 upshift, the 2-4 band is released and the 3-4 clutch is applied. The timing of this shift can cause a momentary torque reversal of the output shaft that results in a clunk noise. This same torque reversal can also occur on a 3-2 downshift when the 3-4 clutch is released and the 2-4 band applied. This condition may be worse on a 4-wheel drive vehicle due to the additional tolerances in the transfer case.
This is a normal condition. No repairs should be attempted.
Info - Rear Parking Brake Shoe Retaining Spring Clip Service Kit for Drum-In-Hat (DIH) Equipped Vehicles #02-05-26-001 - (09/17/2002)
Rear Parking Brake Shoe Retaining Spring Clip Service Kit for Drum-in-Hat (DIH) Equipped Vehicles
2002 Cadillac Escalade, Escalade EXT
1998-2002 Chevrolet Blazer
1999-2002 Chevrolet Silverado (1500 Series)
2000-2002 Chevrolet Tahoe (1500 Series)
2002 Chevrolet TrailBlazer
2003 Chevrolet Astro, Express
1998-2002 GMC Jimmy
1999-2002 GMC Sierra (1500 Series)
2000-2002 GMC Yukon (1500 Series)
2002 GMC Envoy
2003 GMC Safari, Savana
1998-2002 Oldsmobile Bravada
A rear parking brake retaining spring clip kit has been released for service. This kit consists of two parking brake hold down spring clips (2) and bolts (3).
Notice
Use J 46277 Rotor Removal Tool with J 6125-B Slide Hammer to remove the rotor from the vehicle. Place J 46277 between the rotor surfaces in the vent section of the rotor. DO NOT place J 46277 on the back side of the rotor surface, it may damage the rotor surface.
During rear brake rotor removal, it is possible to damage the parking brake shoe retaining spring clip. Order this new kit when replacement of the clips is required but the parking brake shoes do not require replacement.
Important
The spring clip kits mentioned in this bulletin do not address any parking brake concerns. Refer to the Parking Brakes sub-section of the Service Manual for any diagnostic information.
Parts Information
Part Number
Description
Qty
88936340
Spring Clip, Parking Brake Retainer Kit (S/T Models)
Spring Clip, Parking Brake Retainer Kit (C/K, M/L Models)
Spring Clip, Parking Brake Retainer Kit (G Van Models)
Parts are expected to be available October 4, 2002 from GMSPO.
Warranty Information
When removal of the rear brake rotors results in damage to the spring clips on vehicles under warranty, use the following labor operation in conjunction with one of the kit part numbers listed above.
Labor Operation
Description
Labor Time
H2956
Parking Brake Shoe Retaining Clip - Replace
0.7 hr
Add
To Sand or Grind DIH (ONE SIDE)
0.2 hr
Add
To Sand or Grind DIH (BOTH SIDES)
0.3 hr
Add
To Sand Brake Shoes (ONE OR BOTH SIDES)
0.1 hr
    Kirk Belch
    Kirk Belch
  • Who's Online   4 Members, 1 Anonymous, 962 Guests (See full list)
