NEED A WIRING DIAGRAM PLEASE
HELLO
Well trying to battle a p2135 code again. Looking for a wiring diagram of the throttle body wires, i think eight wires, that go from the throttle body to the ecm. My mechanic flashed the ecm and in the past I have replaced the connector and then wires from the throttle body to close to the ecm. I did a sloop -okay job as I was in a hurry. My mechanic says that some of these wires are "twisted wires" to eliminate outside rf interferance. I donot remember any of these being twisted but want to go back with the correct gauge wire and solder and or twist the correct wires. Basically do a good job. I have replaced two throttle bodys, two pedal assemblies, the connector and of course wires. A wiring diagram that indicates which if any wires are twisted would really help. Thanks if you can help. ken
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
