LED concept fog light halos Bluetooth help.
So I installed halos in my fog lights to the blue tooth controller. Here are the two issues I'm having.
1. They turn on sometimes even when the iPhone isnt on. It happens at random times.
2. Today I couldn't link to the Bluetooth via my phone. I tried everything while at the store. On my way home after three stops they worked again.
I'm guessing a short somewhere. Maybe a ground issue. Any ideas.
