2014 LED headlight conversion help?
Neutril
I have a 2014 Silverado.
I'm currently on my second pair of led headlights and I just bought the truck in March. The first pair were from a customs shop, they recommended them to me when I asked for HIDs. There argument was that HIDs will burnout on the drivers side on the new body 1500s. Needless to say i loved the led replacements. They had the fan in the back and were just plug and play with no ballasts. They lasted maybe 5 months and the driver side burned out and started popping my fuse. I went to another customs shop looking for the Oracle led conversion kit but they gave me RacerSport brand. These have a ballast and haven't worked right since I got them. I've had them for 2 months now and they flicker and turn off when the truck is on. When I turn the truck off they come back on. I use to be able to turn the lights off and back on and that'd allow me to drive with them on. But now they just cut off right when the engine starts. And come back on when the engine is turned off. Also these are just the LOWs. The highs are still the old plug and play set(which also burned out but my lows and fogs are as bright as my highs so Im not worried about my highs right now)
Im almost $400 in just headlight bulbs. The next set I buy I want to be sure they last. But my question is, are these led ballasts faulty or is it my truck?
I had issues with LEDs too. I went with OPT7 LEDs and had nothing but trouble after a couple weeks. Seem to be related to heat problems, particularly due to the closed dust cap setup the new trucks have. I went with HIDs, just like I had in my old truck. Not a single issue yet. Also installed them on my dad's '15 and he hasnt had any issues either. I may try LEDs again one day after the technology matures more, but for now, HIDs are great and supply better light output/throw and saturation with the stock housings IMO.
Edit:
I've been using them on my trucks since 2012 and have had next to zero issues.
Hids for the win. No big issues in almost 2 years that I had them
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
I run the LEDs from Xenon Depot. I am swapping to HID, Morimoto with FXR projector swap. But if you like the LED- order the xenon depot H11's. Plug and play and works inside dust caps. They cost $90 total. Those custom shops took your head off with price. Really easy to install the Xenon Depot and they are pretty bright. No canbus connects and I've never had flickering and I run them in my lows and fogs.
I want a more focused low beam projection with a sharp cutoff. That's only obtainable through HID right now.
I'm getting new headlight housings soon with dual projectors so I'll try out the Xenons. It's good to here that they are plug and play and they fit inside the dust caps because I had to mutilate and throw my current dust caps away in order to fit my broken LEDs. But once I get the new housings and xenons I'll post a pic.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 485 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
