WTT - Powerfold Regular Chrome Side Mirrors For Chrome Tow Mirrors
Will drop another $300 on top of the trade located in Houston Texas can meet in surrounding areas. Please just text me, 281-638-5226
I do not mind if they are Powerfold or not but I would really like the upper part to be chrome to match my Texas Edition.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
