Rear high mount cargo light
15LTZ
I just got my 1st Silverado after having all Dodge Rams...It's a 2015 1500 LTZ. When I used to hit the unlock button on the remote for my Ram, the rear high mount cargo light would come on along with the interior lights. On the Silverado, that light only seems to some on it you hit the button on the dash. Am I missing something or is it just the way it is on the Silverados?
I believe it's just that way.. I have the 15 Denali ,however, in this forum there is a mod that allows that function to take place.
Sent from my SG Note 4 on Tapatalk
There is a way. There's a thread on this bc I have mine set up this way. You'll use a resistor.
Found it. Search "cargo lights on with reverse lights" this mod will cost you about a buck.
Just quoting you so you would see my response above And it would show up in your inbox.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 696 Guests (See full list)
