what hitch to buy
please help im wanting to install a gooseneck hitch and dont know which way to go  ive heard of a hitch that you can remove the ball by pulling a lever by the wheel      does any body know who makes it and is it bolt on or welded
thanks i will try and find out more on them and see if i can install it    willthe bed need to be lifted off or can it go on without lifting it     and will the double crossmember for the bed need to be removed     once again thanks
Dad's truck, Grandpa's truck and mine has the B&W Turnover Ball hitch..
Note: when you get it, it will be gray.. prime it black and paint it black or undercoat it or else it will be well on it's way to rusting in less than a year. Trust me.
Only cutting required for my truck was the bed and a heat shield for the exhaust pipe.
A 4 inch hole saw works best for the bed.  measure twice... cut once
I loosened the bed bolts to lift the bed a bit from the frame to get the cross members in.  Taking the spare tire off also helps with working space.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
