Scratched Headlight Lens Fix?
Tim99GT
Has anyone ever repaired a scratched headlight lens? I had a cut branch scratch mine the other day and one area is fairly deep on the corner edge of the lens by the blinker cover.
Is there any filler that could be used to fill the scratch (clear) to where i could sand down and polish after to smooth everything out to where its not noticeable? Trying not to have to buy another headlight due to my OCD haha
