Engine turns over but won't start.
2007 Classic Silverado 4.3L
So here's what I've done:
Listened for fuel pump - working.
Pulled sparkplugs - wet and dirty - cleaned.
Wire set - Corrosion in spark plug boot - half ass cleaned.
Distributor Cap - Moisture and corrosion - Cleaned like new.
Can't check for a spark without extra hands. Till I find some... what else can I check???
Sent from my SM-N900V using Tapatalk
You're on the right track. Get a warm body to help check for spark.
Also may want to try some starter fluid spray to eliminate fuel delivery issues.
Checked for spark and all cables fired.... the sparks were weak but I'm guessing it's due to the being used battery so much.
You need to test the fuel line pressure. Just because it runs, doesn't mean it has adequate fuel pressure.
So I got her running again. I replaced the Distributor cap and the rotor but no go. Then went ahead and replaced the plugs and wires... fired up on the first try.
A few of the wires were damaged when I pulled them out to replace them and also the plugs were dirty af again.
I don't like the gunk that I saw on the plugs when I pulled them out. What can I do to clean out the cylinders???
    ar0517
    ar0517
  • Who's Online   0 Members, 0 Anonymous, 582 Guests (See full list)
