**Warning** 744X LED bulb tips
morrislee
I am not sure how many of you out there are having fitment problem with 7443 signal bulbs, here is something you should do to the cheap LED bulbs out there so they sit properly in the socket and stays that way.
Make sure you use a dremel or sorts to take out a small area of the plastic like the following where the black tab no longer pushing the bulb out of the socket
I thought my turn signal was out but it turns out that it was just slowly sliding off the socket, be warned!! your "error cancellator" or "resistor" will prevent you knowing your signal lights has stopped working, I only found out when I went to unlock my truck in the dark.
Drive safe everyone!
    Afennell19
    Afennell19
  • Who's Online   1 Member, 0 Anonymous, 988 Guests (See full list)
