K2XX 2014 - 2015 GMC Sierra Dark Graphite Front Bumper Skid Plate
So crazy I was quoted $550 to fix it. 350 for the skid and 200 for the labor, said you have to remove the bumper. I'm considering this. Though I do want a black one as well. I'll keep you updated.
The labor isn't terrible. You don't have to remove the bumper. You just have to take the lower air dam off, then take then swap these pieces out and put the air dam back on. It's not hard by any means.
Irrelevant post, but I'll go ahead and correct you as I get tired of the ignorant comments on this forum....by part number and description GM refers to this as the front bumper skid plate.
LOL!
Relax, it's the internet......Everybody does not know the proper terms for their truck parts. It's going to be alright.
Not sure what your deal is with people on this forum, it's the best and most friendly GM truck site on the web IMO. If you're offended here................
Sent from my crappy iPhone 6
using Tapatalk
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 413 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
